Pressure dropping onWorcester 28i boiler
View the thread, titled "Pressure dropping onWorcester 28i boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
K
Keith Stulberg
Hi, Any help greatly appreciated. I have a Worcester 28i Boiler. Pressure keeps dropping to almost zero and I keep re-filling every day to 1.5 Bars. Boiler is definitely venting water to outside (pipe on outer wall is directly behind boiler). Is there anything I can do. I do not have Boiler cover. Boiler is about 7 years old. I am not mechanically gifted!
Simples, no, you shouldn't touch it, you may make the problem worse, cock something else up. You need to speak to a local gas safe chap to come and have a look.
As secret squirrel rightly said -
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Pressure dropping onWorcester 28i boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Keith Stulberg,
Dotty,
