Dec 1, 2019
11
DIY or Homeowner
I have a Vialliant ecoTEC pro 28 . last week or so it has been a bit temperamental ,sometimes comes on sometimes not .the answer was generally to add more water , my fill loop only has one tap to fill and that on;y fills a little ,i always remember two taps ,,anyway i get the usual F 75 and press reset makes the usual noise and starts up , last few this has not happened ,i have to open the the tap for a second or two and hear a little bit of water going in it then works as normal , pressure says 1.6 , this does not change , after some searching i think it may be a water sensor problem , any advice would be great
Ideal pressure is 1.5 bar and no more. There are a variety of reasons why your boiler might loose pressure. The difference between zero and 1.5 bar on a normal domestic pressurised heating system
is about 5 litres or two large coke bottles. There is a protocol for checking this type of system
1. look for obvious signs of damp 2. Check the prv the valve that goes to outside ..they can weep
3. watch the pressure as it can go up and then drop...thats a boiler problem.
How often does it loose pressure that is crucial in id the problem. ?
centralheatking
Not for a few years and then i thought there was two taps,
[automerge]1575225360[/automerge]
just checked the boiler, heating been on for 3 hours or so the screen is showing 3.6 bar . i think this is far too high
Cheers Stigster , I could top the water up thats all ., no danger of me taking the cover off .
Now angus here is how to mitigate your problem. The expansion vessel that fits inside and at the back of most combi boilers will be quite expensive to to change in terms of labour and the bespoke part. My advice is after consulting with your GSR is to get a suitable capacity exp. that can be fitted eleswhere...they are really cheap...look at
BES at Electric Ave Brum and do the same job...say the boiler type is £150 the generic one will be about £40.00....others will comment ...centralheatking
  • Agree
Reactions: Stigster
Thanks CTK/Stigster , guy coming out Wednesday afternoon to have a look i will remember that advice .he comes highly recommended by people i know .. which is always a good thing
