pressure loss and air in ground floor rad and top foor towel rad
View the thread, titled "pressure loss and air in ground floor rad and top foor towel rad" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi
Towel rad in bathroom needs bleeding every few days and now noticed a small rad downstaris also has air in it regularly. Pressure drops every few days and needs topping up. I've tested with a flame for corrosion and it's clear, tried leak sealer and checked for weaping rad connections . I cant see anywhere that's leaking and cant figure out why air is regularly getting into the small rad in downstairs bathroom as well as the towel rad upstairs.
Any ideas please?
thanks
More information please
Type of boiler combi or system/heat only
Have you checked pressure relief pipe outside?
Expansion vessel checked for correct pressure?
Hi
Combi boiler,
No escape from pressure release pipe. Expansion vessel was re pressurised to manufacture spec about 4 months ago when boiler was serviced. The problem has been ongoing now for about 6 months.
Id assumed air would collect in highest rad and not not come across air collecting in small downstairs rad before.
Hi
Combi boiler,
Reply to the thread, titled "pressure loss and air in ground floor rad and top foor towel rad" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
markbebbs,
markbebbs,
