Oct 12, 2008
187
31
28
Hi - called out to a property yesterday. The guy was complaining the toilet cistern was noisy filling and the valve closed with a thump. I found by closing down the main stopcock it solved the problem, The stopcock is now just about one half turn open , there is still plenty flow at the taps and the cistern fills quietly , but wondering if should recommend fitting a pressure reducing valve. Never fitted one before
thanks
dave
Was there an electric shower fitted? If so turning down the stop-valve that much will affect the peformance. Was there not an isolating valve at the cistern? Sound like a problem at the ballvalve
Scotty I have to disagree with you, why would there be a problem with the ball valve? just sounds like v. high pressure.
Also shutting down isolator on cistern will cause excessive noise if it is high pressure, Pressure reducing valve way to go imo
Most cistern ball valves should be able to cope with high pressure water, If it makes a thudding noise when shutting-off i would be pretty sure that it would be a torbeck style inletvalve there fore i would change it to brass styled one ( if possible) as they shut off more gradually which would prevent the thudding.
Getting a lot of pressure problems here in the SW, due to water board relining pipes, shower / taps / ball valves ect not likeing it also combi - boilers so best to fit PRV to serve all of house.
You could also considder fitting a shock arrestor, especially if fitting a prv you'll need an expansion vessel 🙂
Diamond an expansion vessel is not required on a cold water main?
I thought it was required if you fit a pressure reducing valve! What takes up the expansion of the cold water in the pipework of the house when the heating comes on and heats it up?
Im with diamond.on this. I thought you should use one but depending on pressure. 6bar and upwards iirc
Sent from my GT-I9100 using Tapatalk
No EV required on cold water main! The pressure reducing valve only reduces the water pressure and has nothing to do with heating up the water or it expanding!
See my understanding is that a pressure redcing valve will shut off the return path to the mains incoming and isolate the domestic installation .... if so what takes up heat expansion in the cold water pipework?
Reactions: 2 people
when cold water enters a property it picks up the heat in the property, this causes expansion and an increase in pressure. if prv installed, this will prevent expansion being taken up by the incoming main and you need an exp vessel
Could this expansion be a flexi hose killer ,
( Was thinking washing machine hose will allow some )
What would Iv of pipes after prv be ? ( for a 4 deg to 22 deg average )
The main risk is on sections of pipe between non return valves and stop taps and pressure relief valves etc where there is high pressure and a possibility of heat expansion. Often a mini arrestor is sufficient and will protect appliances like combination boilers etc
