id use a dry test kit and pump it up to a couple of bar to be on the safe side as its being buried dont buy the kit which is about £60qouid the cheap 20 one is all you need easist if you have a small compresssor handy but foot pump or bike pump works the samehi guys, can anyone recommend any pressure test equipment for gas. ive installed some pipework prior to a gas meter fitted in a house and want to test pipework that's going to be buried....cheers.
trouble with a manometer test is its such low presure ive seen fluxed but unsoldered joints hold up on a gas test plus you cant denso beforfe testing which is dificult to do once its laid on a slab in one continuos run the other plus of course is if you have got a leak its a lot easier to find with 30 psi whistling outId use a manometer and a bulb pump and a couple of small vales to connect into the pipework and do a standard pressure test for pipework. All parts available from BES for about £20. Surely the dry pressure test kit for piework carrying water isnt accurate enough for gas work, only my humble opinion.
Reply to the thread, titled "pressure test equipment" which is posted in UK Plumbers Forums on Plumbers Forums.
