pricing up for little job
View the thread, titled "pricing up for little job" which is posted in General Plumbing Jobs Discussion on UK Plumbers Forums.
I also have a little part time occupation working with 320 hp caterpilar engines, the fuel line are in copper in places and can run at very high pressure, on the injector side and all that stops the diesel from spurting all over the engine room is a brass nut on a thread with an olive to make the seal, funny how I dont have fuel everywhere and theres not a sign of ptfe or jointing compound in the place. SP you need to shut up and listen and learn, at present you know the sum of diddly sqat and are making yourself look foolish. its good to see your attending a college, just start learning how to do it right and proffessionally and no more pics of your work, its a nighutmare that brings this trade into disrepute.
As above good luck and get learning the right way. A change of name would help
[video=youtube;-9c5LWFI_M4]http://www.youtube.com/watch?v=-9c5LWFI_M4[/video]
Must be wrong though because he hasn't used any paste or ptfe. At the most I would use a small wipe of paste on the olive.
"Nout wrong with that" should be followed by "is there ?"
are you actually taking the mick here ? Is this a set up ?
What have you used ptfe tape atall ? Its a new fitting is it not ? Did you use copper olives ? This is an actual joke ! I wouldnt spend that money id save it for the excess on your PL insurence ! Best hope you have it since youve already strained the nut and as soon as it freezes ! POP !!
Go show this to your college see what they say !
a compression fitting is designed to not need any paste or ptfe tape. Its only the fact that many are made poorly or there are slight pipe inperfections that we tend to use something for added peace of mind. I would normally recommend to use no paste or tape , because most use too much and make thing worse.
some pastes may not be suitable to use with tape, best to use either one or the other.
theres no point to putting tape on a compression fitting thread, it wont leak down a thread on these fittings as they are nowt to do with the water seal.
Please dont take any comments on the forum as a negative, we all learn from discussion of these things. There will be as many people reading the thread thinking i do the same as thinking you dont need to.
Who wants to start the bidding on whether he gets called back or not.
£30 should have just about covered materials then looking at that. If compression fittings needed ptfe they would all be supplied with a roll when you buy one.
Fair play to you for putting he pic up and taking the criticism well. Not much I can add to the many many comments since. Put it down to experience and move on. Next time it will look very different.... WON'T IT?!
Maybe the poor lad wasn't taught incorrectly maybe its his understanding of what he's learnt,
I don't think he believed his work to be slatted as bad as it has been, no one in there right mind would put up that pic knowing it was so bad.
With any luck he won't be scared to come back and ask a bit more......
Nothing wrong with making a mistake as long as you learn from it. We've all done something daft in the past.
I have stuck a 32mm core in the wrong place because I didn't draw clear lines.
I once got a woodchip in my eye because I didn't wear safety glasses using a circy saw. Had to pick it out with a knife.
I also forgot to cap off ALL the pipes on a bathroom first fix. Legged it back to stopcock when I heard water gushing from the pipes for thermo mixer shower.
Point is, make a mistake, live and learn!!
High five supper plumb for posting that picture up, that takes some balls. you have also taken the criticism well.
good luck with the training and maybe keep the pictures to yourself next time.
This thread is hilarious.
Supper Plumb, change your name to shoddy plumb, ditch your "mentor" as he is clearly a tit who shouldn't be allowed near clean water, then find a real plumber. You'll never learn anything from this guy if he can't even fit compression joints.
Many years ago when I was the apprentice, I told the guvnor I didn't think the compression joints on rad valves needed paste.
He said fair enough fit them without any.
They then left me to drain down and remake all of the joints again as most of them leaked.
Needless to say I have always put a lick of paste on the shoulder of the fitting since.
I'm working with a guy who uses PTFE on big screwed joints, he looks at me as if I'm soft when I pull a reel of loctite 55 out, PTFE is crap IMHO especially the cheap stuff and that photo made me laugh, definitely no PTFE on comp joints!!!
Reply to the thread, titled "pricing up for little job" which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
supper plumb,
Dan,
