I
ITEK
Hi guys, first post on what looks a very helpful site so here goes!!
Fitted a Salamander CT75 pump today in a bathroom refit. Pump is fitted under the bath taking hot feed from what was previous supply to bath tap and cold feed direct from cold water tank in loft. Hot and cold water flow through the bath taps fine, however the pump does does not start (shower) even though water flows through the pump with flow routed to the shower mixer, where water comes out -although not tremendous pressure. There is power to the pump. I plan to call Salamander tomorrow but wondered if anyone had any suggestions this evening?
Thanks in advance for any advice.
Ian
Ian
