I have problem in waste pipe of bath which only drains if I plunge it. I made sure there are not any blockages further down the line of the pipe. Apparently it needs Air Admittance valve to let the drain flow freely. Another experienced plumber suggested that if you attach anti-syphon waste pipe to the sink which attached to the same pipeline will do the trick. do you believe if this solution works? if not why not?
