Problems with small bore pipe and an old central heating system
View the thread, titled "Problems with small bore pipe and an old central heating system" which is posted in Central Heating Forum on UK Plumbers Forums.
74EBAB47-FAFD-42A8-BF81-C0002730141B.jpeg9F1955B3-7603-4E16-8E22-80E2D164D5C5.jpegA5B882F5-C0C6-4278-AAC5-1CB028734A15.jpeg
Update. Central heating has now been running ok for the last few weeks with X800. Every few days I have been cleaning out the two magnacleans I installed. Last time was today after I left heating on timed (one hour in the morning and one hour in the evening) for the last 8 days. It collected magnetite as per the photos attached. Should I leave the X800 in for a few more weeks until it collects no more magnetite or drain and fill with inhibitor now ? Many thanks.
Update. Now into December and with the X800 still in system I continue to collect weekly amounts of magnetite. See pictures. When is the right time to drain the system and add x100 ? Many thanks.
Update (October 2023). System still running perfectly. I drained down in the summer and put new inhibitor in. Recently powered up and the central heating is running well. Still collecting the debris in the 2 magnacleans I fitted at the troublesome spots on the system (entry into the small bore pipes leading to the radiators that did not heat up) but I dont mind cleaning them out every month. Rather this than spend £2k on a power flush that is not guaranteed to work and may cause no end of problems on my 40 year old multi pipe (normal and small bore) system! Learnt a lot on this forum and if I had my time again would not have allowed these so called 'professional plumbers' to install small bore pipes in my system!! Thanks again. Cheers.
Reply to the thread, titled "Problems with small bore pipe and an old central heating system" which is posted in Central Heating Forum on Plumbers Forums.
jh2254,
jh2254,
