K
keyte1
Hi all, hope someone can help me I have a problem with a Halstead Eden CBX combi.
When the boiler is running in CH mode there is dripping from the is charge pipe linked to the PRV.
The gauge pressure cold is 1 bar hot 1.5 bar all correct. I've changed the expansion vessel as It had no pressure and water discharging from the schraeder valve. I have now replaced the PRV against my better judgement and I still get discharge when the system warms up. There is no overheating or temperature issues symptoms. The filling is connected but I have isolated it both ends.
Halstead tech help is premium number and on the occasions have called them they were useless.
I have two requests first PRV fault suggestions.
Secondly can anyone let know of other manufacturers who charge premium rates for tech support.
I am holiday for week so may be slow responding to your posts u any help will be greatly appreciated.
Regards Keyte1
Is the pressure gauge faulty?
It could well be, but when refill the boiler at responds as you would expect. I am trying to avoid replacing parts in process of elimination which is very expensive. I may have go down that route. But as I should said at the start thanks for your help!
Sorry I didn't respond before I was on holiday and my internet connectivity was unreliable.
I have 2 questions
How do I update my profile to show I am gas safe registered I am very new to this site?
My second question is back to my original post.
