PTFE Tape or Blue Stuff For Loose Fitting
View the thread, titled "PTFE Tape or Blue Stuff For Loose Fitting" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I'm fitting a shower and I have a screw in fitting for the shower rail that I want to install as illustrated below. I can't screw it tight as the finished orientation won't let me and a dry fit is very loose. I just want some advice as to whether a good thick wrapping of PTFE tape would be better for this than the That Rapid Blue Stuff sealant. I think I'd prefer to use the sealant, but just having second thoughts because it is so loose.
Advice appreciated!
Thanks,
Alan
Ok thanks. Just especially worried about leaks as behind panel.
As it is loose I think it will need a lot of wraps and I'll smear some jetlube v2 on outside as well. Then keep fingers crossed.
Roughen up the thread on the male section.
Scour the thread with some multigrips or hacksaw blade.
The put the PTFE tape on.
Roughening up the thread helps the PTFE tape stain in place rather than slipping up the thread when tightening.
Much like the old days when using hemp
I last used the belt and braces approach to this problem.
Thin layer of sealant on thread, then wrap PTFE not excessively thick, then another layer of sealant!
You will soon find the correct thickness to obtain a snug fit.
I have also used garden twine wrapped on thread with a layer of sealant - this is similar to the hemp thread that someone else has mentioned.
Never use sealant prior to applying PTFE or Hemp
That's why 'roughing up' of threads was always used when using Hemp, & PTFE to a degree.
You can apply sealant over the Hemp or PTFE and sometimes a smear inside the female fitting.
Reply to the thread, titled "PTFE Tape or Blue Stuff For Loose Fitting" which is posted in UK Plumbers Forums on Plumbers Forums.
alan_f,
oz-plumber,
