View the thread, titled "Pump Differential" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Chalmers7
Working on a commercial system and the Grundfos 32-80 single headed pump has a gauge before and after both saying 2bar.
the pump is spinning and no circulation is happening,
both circuits of the header have the same problem but a third set of pumps show 3/4 bar differential.
does anyone thin k this sounds like the pumps shot????
Are you sure the pump is spinning and you are not just feeling a buzzing from it? If it isn't, then the condenser (capacitor) is likely shot and so replace it. I think they are 2.5 microfarrad but you would have to check.
If the pump is actually spinning, check the pipe circuit. Could a bypass valve be too far open?
If the pump is spinning but sluggishly, then the motor windings have deteriorated and I'm afraid it's a replacement.
To check for sure, take the pump off. rig it up to a header tank full of water and run it. If you can place your thumb over the end and stop the flow, it's the motor.
Reply to the thread, titled "Pump Differential" which is posted in UK Plumbers Forums on Plumbers Forums.
