View the thread, titled "Pump on hot water system" which is posted in Bathroom Advice on UK Plumbers Forums.
M
MrT
Hi
I have been called to a customer who lives in a bungalow with gravity fed system and is not over happy with the water pressure in hot taps as it takes a while to fill her bath.
I mentioned in passing whilst doing another job for her that a pump on the system would boost pressure and now she is dead keen.
Can i just put a circulation pump in the airing cupboard on the floor next to the cylinder and connect in to the hot water supply pipe or would a shower pump be better as they turn on when there is flow? she wants a boost to all three HW outlets. i.e. bath, basin and kitchen.
Didnt expect her to go for it and now looking for advise as not done this before!!!😱
as long as the pump is low pressure prob is hot tap at sink and basin could be an issue as too much pressure and it will shoot everywhere with scalding an issue
already 22mm to bath which is the real low issue so cant really increase this here. there is about 350mm to play with under the bath where it comes out of floor.
with a circulatory pump surely she can just turn it on for the bath and just use gravity for the rest or would the pump itself restrict flow further to the basin +kitchen
Have a look at the salamander website. I think you can get pumps that cover what you want. They produce a system pump, not a shower pump. Depending on the type of pump you want its not cheap. Then you have all the other fittings and your time....
thanks chaps
Safe to say after much effing about and squirming i was able to fit a larger bore flexi on the tap than the existing which increased flow from around 4l/min to nealry 11!!!
Thanks for all the advice
i appreciate your point however i was fitting a new tap on old bath and access was shocking - got a 19mm bore flexi on and customer very happy now!!! thanks
flexi is fine as long as its not too restrictive have them on my bath 22mm copper then flexi and flow is excellent why faff around with solid pipe when the flexi is just as good and more workable in tight spaces
copper is fine when you can get to it mut not a lot of fun in confined space
ah but the taps will never last that long and will go through at least 2-3 sets in that time and its far easier to change a flexi hot tap is ok nearest to u but that bloody cold tap stuck right behind everything is a pig
Flexis have there place when taps are designed for them but other than that avoid. Its lazy, unsightly, and does it show us a proffessionals? I dont think so.
The pump also described on this post is a circulation pump for central heating, would it increase the flow of water?
not sure lazy is correct and as for unsightly no ones ever crawled behind my bath panel for a peek yet and i read it that he wanted to add a pump to the hot supply for the taps and nothing to do with the heating pump🙂🙂
circulation pump wld prob increase it marginally but not drastically but too powerfull and it will cause probs for basin/sink etc prob ok to add 1/1.5 bar pump for bath but then you have the drone of the pump if you have it in the bedroom airing cupboard and you fancy an early or late bath and someone is kipping at the time
Reply to the thread, titled "Pump on hot water system" which is posted in Bathroom Advice on Plumbers Forums.
