pump valve connection advice required pleaseeeeeee....
View the thread, titled "pump valve connection advice required pleaseeeeeee...." which is posted in UK Plumbers Forums on UK Plumbers Forums.
pappasmurf
hello fellow plumbers..... just bought a Grundfos UP20-14 BXA PM secondary return pump.
the connection on the pump is oddly 1 1/4" as appose to the usual 1 1/2"
my question is...where can I purchase a 1 1/4" to 22mm "ball valve" pump connection (not a gate valve). Many thanx in advance.
you guys are having a laugh aren't u!....ball valves are far superior to rubbish stiffened up spindle leaking gate valves!!!.... anyways does anyone know where I can get one please?
lame plumber I have tried everywhere!!!..... I can't even find it on-line!!!!....help!!!
if you go into "Tool station" website and see item no. 52920.... this is exactly what I need but 1 1/4 to 22mm
helpppppppp
Nope!
Ball valves leak first time you use them. Gate valves you can tighten or repack the gland
If you mean the slotted pump valves then not sure where you'd buy them in that size...They are double crap btw, always have been always will...Turn off bleb of water bleb of water ffs drain down swap the valves time.
Reply to the thread, titled "pump valve connection advice required pleaseeeeeee...." which is posted in UK Plumbers Forums on Plumbers Forums.
pappasmurf,
AWheating,
