Beboers
Hi Guys,
I have a customer with an ancient gas boiler which is connected to a hot water cylinder above it which then carries on to the f&e tank in the loft. The problem that is occurring is that over the period of a night the overflow starts flowing to outside from the cwsc which is being made warm by water pumping over from the hot water tank vent pipe. I thought it must be the boiler (if you can call it that) thermostat playing up and boiling the tank over but we turned the stat down and ended up with Luke warm hot water and it still overflowed after the evening!There are no other controls just two flow and returns feeding a cylinder and a heat leak rad controlled by a thermostat on the gas heater. Any Ideas chaps??
Thanks in advance!
oh I also presume it is not a split coil as th f&e is sited below the cwsc which is the on overflowing.
please help!
Thanks in advance!
please help!
