View the thread, titled "pumping probs" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
cam
HI all my first time on here be gentile. I have a pumped shower hot & cold. all pipe work as per pump manufacturers instructions for a neg head pump. From the pump the pipe work runs up into the loft across loft and down to mixer after using shower the pump stops and starts every 5 mins untill you turn off the pump do i need air bleeds in the loft as this is the highest point in pipe runs thanks martin
thanks tom, the pump i have fitted has its own non return valve, im on the second pump (first went back)
Take it you've got auto air vents at highest point. Sounds like a small leak down stream of pump
Reply to the thread, titled "pumping probs" which is posted in UK Plumbers Forums on Plumbers Forums.
