I have some radiator pipes to alter under a floor in a bungalow I will drain off from the drain point on a radiator to get most of the water out then cut under the floor. Is it likely I will manage to get all the water out to unable me to solder?
thanks just cut and it should stop running enough to solder after a while?
i used push fit 20years ago on my gaff copper to copper because I was being lazy boyIs it ok to use push fit connections on old 1/2 copper. I know you need adaptors for 3/4 to 22mm. Thanks
