View the thread, titled "Pushing water up hill" which is posted in Bathroom Advice on UK Plumbers Forums.
billybongo
Could one of you clever bods tell me how you calculate pushing water upwards.
Ie what pressure would you need to push water 10 meters up into a tank from say a six inch water main . cheers mark
you would need to find out what downward force gravity has on the water, and then find out how much pressure you need to overcome that force to push it up into the tank. This could be done with a little bit of research.
Unless you are in a particularly low pressure area you should easily get enough mains pressure to get the water up 10 metres. Anything above a bar will do this.6 inch main?! Are you sure? Size of the main doesn't matter anyway.
Hi. To do calculations more information needs to be known. Litres per second, pipe size, length of pipe. This can be used to calculate the head required
Thanks for your interest, I am just trying to second guess some project engineers where I work , it's a possible water supply from Anglian water apparently 12 inch into site running in 6 or 8 inch for approx quarter of a mile to a large braithewate tank 200 cubic metres approx. The in coming main is max 3 bar and can be to the minimum which is around 1.7 bar . So my interest was would this pressure be enough . Cheers Mark
hi. Taking the average @ 2.35 bar (23.5 metres head) and 150 mm pipe over 400 m the discharge would be around 43 litres a second. If you minus the 10 m head (rise in ground perhaps) Discharge 32 L/s This is a rough calculation using boxes formula. Full bore discharge, no doubt there will be a ball valve at the cistern end, or some type of water level controlled valve. Which effects the volume of discharge.
Reply to the thread, titled "Pushing water up hill" which is posted in Bathroom Advice on Plumbers Forums.
