PVC pipe replacement
View the thread, titled "PVC pipe replacement" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi, I have a white pvc pipe that goes from inside the house to the outside gutter. The pipe is concealed in the house and goes to a downstairs shower. The issue, as I hope the photo shows, is that the pipe has broken near the outside wall. I can't take the concealed pipe out.
Can you give me some tips on how I can replace or join a new pipe?
Should I just glue a smaller diameter pipe to the inside wall pipe and attach the sheared one - is that the best option?
Carefully remove the cement / mortar around the pipe then you can glue a new elbow on or coupling etc
Don't re-use the sheared-off section. It will all have become brittle due to exposure to sunlight. The replacement should be specified a suitable for exterior use. Black plastic lasts better than white plastic.
Good point, I was going to use the same pipe. Will buy new suitable for outside along with some PVC glue and elbow. Thanks
Reply to the thread, titled "PVC pipe replacement" which is posted in DIY Plumbing Advice on Plumbers Forums.
Mesh44,
Mesh44,
