Question about Cold Water Booster Set
View the thread, titled "Question about Cold Water Booster Set" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi Gents
I have problem with pressure in my house. Plumber advice my to read about cold water booster set, it is grate solution in that kind of situations i read. I think i will go for one of this device. My question is how do you sizing this to the property, what should i take into consideration. What is the best quality for money???
There is an alternative. Just call the manufacturers and ask their advice. I have never yet been let down by a manus advice re pumping. All ask extensive questions to make sure you get what is appropriate.
What mains pressure and flow rate are you currently getting?
pressure maybe 1 - 1.5bar but i will have to checked, flow rate no idea is it meter?
have dedicated space kind of utility/plant room but is not very much, not for 1000l or more this 500 looks grate and it will fits, but i am not sure if the efficiency will be right or might be to much and i will spend lots of money needlessly
How is your hot water heated??
system boiler and cylinder
eye watering ...pun...price...I would want to know much more about the property before making any advice just yet
centralheatking
What you need to know?
plenty but busy till later m6 stuffed again chking
Reply to the thread, titled "Question about Cold Water Booster Set" which is posted in Bathroom Advice on Plumbers Forums.
Mateus,
Rob Foster,
