E
emmablue29
Hi everyone,
I have a problem and just looking for some advice or suggestions on what might be my problem.
Recently moved to a two bed flat, been here for 5 months. Since we moved in, we've had very low pressure on the hot water taps in the kitchen and bathroom (sinks and tub). It takes 30-40 minutes to run a bath and 10 minutes to run the sink in kitchen to wash up.
Upon contacting the waterboard (Severn Trent) they said that low preassure on the hot water is a plumbing issue and has nothing to do with them. If it was cold water, they would have to fix it or provide a discount on water. Well, the cold water is fine.
So I've been putting up with the situation thinking it might be normal. We recently had a water meter fitted because we were just paying a standard yearly rate. When the plumber from the waterboard fitted it he commented on the water pressure and said it was ridiculously low and he'd never seen anything as bad as that. He suggested that it might be because in a house, water usually falls from a tank from an upstairs room thus gaining gravity's speed. Being in a flat, the water runs straight and doesn't have the advantage of gravity. I thougth good point BUT we moved from a different flat in the same building (same set up) and the water pressure was fine in that flat... He said it is definetly an issue that needs raising with the landlord. I told the landlord who has been taking his sweet bum time to 'consult his plumber'.
He finally consulted his plumber and has basically said that the previous tenants never raised an issue so he's blaming it on the fact that we got a meter installed. Even though it was like that before the meter was installed... he said he won't investiagte it further without the waterboard doing some checks. Personally I think he is just beating around the bush... he tends to do that.
I spoke to the waterboard today and they are going to contact me in due course about obtaining some kind of written evidence that the low pressure has nothing to do with them and needs addressing.
Anyone experienced similar problems or know if it is a 'fixable' problem? Is the landlord obligated to fix it at all? What is the problem with the water!?
Any help would be greatly appreiciated.
Emma
Emma
