Question Re. Wire/Spring Clips Used In Boilers To Secure Internal Pipes
View the thread, titled "Question Re. Wire/Spring Clips Used In Boilers To Secure Internal Pipes" which is posted in Boiler Advice Forum on UK Plumbers Forums.
This is just a quick question. Today I have removed the DHW plate hex on my Valliant Turbomax. One pipe to the hex was held on with a nut and had a 1/2" fibre washer. The other 3 connections had wire clips. All is ok, and the hw is now scalding after a good cleaning of the hex.
I'm unsure how you are supposed to use these spring clips on reassembly. Do you -
1) Push the stub of the hex with the o ring into the end of the pipe ( ie. the union) the put the clip in.
or
2) Do you put the clip in it's groove first, the slide the hex's stub in, so that the stub clicks into place.
Sorry it's a basic one!
Thanks very much. Yes, that makes sense. Didn't consider that it might catch on the o ring. Clips in last is the method I used anyhow. Didn't have any problems with these connections. Just a slight weep on the nut and fibre washer one. Little tighter and all OK.
Thanks again.
Reply to the thread, titled "Question Re. Wire/Spring Clips Used In Boilers To Secure Internal Pipes" which is posted in Boiler Advice Forum on Plumbers Forums.
plumbandplumber,
plumbandplumber,
