C
chrisab
I've purchased this low pressure mixer valve. Gravity system both hot and cold so should be roughly same pressure (allowing for different losses in pipework). Do i need a check valve (or even double check valve?!) on both the hot and cold inlets or are they not needed for this setup?
[DLMURL="http://www.tapwarehouse.com/product/BQ333-V"]Vellamo Pixo Thermostatic 2 Outlet Shower Valve[/DLMURL]
Also, do i need check valves on this mixer tap?
Vellamo Pixo Basin Mixer Bathroom Taps Modern | Tap Warehouse
many thanks!
Chris
ok thanks for the info, thought that would be the logical case - but then these regs normally aren't are they!
If the cold water storage cistern is correctly covered and insulated it will still be potable. That's why we have to fit a bylaw kit.
From what I remember from college (a few moons back) it's fine to feed a bathroom tap from a correctly installed storage tank, it's only kitchen and dedicated drinking taps that need to be mains fed.
