The system is open vented with a Glowworm boiler. It has an LCD controller on the wall - see pic.
I just want to remove one radiator for cleaning and decorating the room. I will put it back the same day.
If I switch the hot water and central heating off on the LCD controller several hours before I remove the rad will that be enough? Or do I need to switch anything else in the system before I begin?
I shouldn't have to drain the system. Is that correct?
Do I keep the system switched off while the rad is removed?
When I refit the rad should I refill it with water before turning on the system? I assume this way the system will continue with the same pressure etc when I turn it back on.
I have a Central Heating Dosing Tool so refilling the rad should be non messy.
I also need a new controller so any recommendations would be welcome. Budget £150.
Thanks in advance
Thanks in advance
