Random banging from coldwater pipes
View the thread, titled "Random banging from coldwater pipes" which is posted in Bathroom Advice on UK Plumbers Forums.
T
Tony Bushell
Can someone please help me?
I have quite a loud banging from my coldwater pipes, it happens when I turn off the coldwater tap but also at random times throughout the day (even when i'm not using any water). I had a plumber come to look at it today but he said he had never come accross this problem before and that he couldn't explain why it was banging when the cold water was not in use.
Does anyone please have any suggestions.
Tony
puddle is on the money, fiddle about with the toilets valve, push down the float and slowly close it, see if that makes it bang.. same with the taps and same with the valve in your loft or any other tank you may have thats fed by a ball valve
sounds like a dodgy float valve in wc or in cwsc in loft, I get this all the time.
In the wc if its bottom feed try usind fluidmaster pro much better and use less space!
Tony,
Did you ever manage to find what the problem was / get it fixed? I have a similar problem that's exactly as you described. Have shut off every appliance connected to the cold water in the house individually but cannot find what is causing it.
Reply to the thread, titled "Random banging from coldwater pipes" which is posted in Bathroom Advice on Plumbers Forums.
Tony Bushell,
rtrevor,
