lordyjordy111
Hi people
I'm a trainee heating engineer and have posted on here quite a few times now
my sisters boiler is a raven heat and when she turns on the hot tap in the bath it is running fairly hot then cold.
also at the same time the room stat is turned off but the flow pipe is getting hot on the rad when I turn the bath (hot) tap on
I believe this is the divertor valve inside the boiler????
another problem is the she keeps topping the pressure up but there is no leaks on the system.
it loses pressure instantly (without heating up and out prv beacause expansion vessel)
any thoughts? i think new boiler
