Hobo128
292
32
28
Manchester
Hello,
I have a problem with a Ravenheat LS80 T. No hot water and No heating. I can't find anywhere the Installation instructions (Online) I'm thinking it's the PCB but as I am just getting into fault finding on boilers I want to be sure. So here's why i'm thinking it's the PCB. Turn the boiler on pump gets 230v Pump proves then fan gets 230v, Air pressure switch is working then after that it goes to lock out.Gas valve doesn't get voltage. Any help would be great. Thanks.
No help in the public forum as per the rules
Hobo are u sure the air pressure switch is working ?? have tried for continuity at each l terminal while puting it on and off just to make sure its making n breaking, Because some folk stick a multimeter on air pressure sw and think oh voltage here, but thats on one side, when the switch makes then check the other,
