View the thread, titled "Reccomendations for replacement leccy shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Plucky
Tend to stay away from bathrooms but a mate has asked me to replace an old mira electric shower. The current unit is an 8.5kw with surface mounted pipe and cable (enclosed in some trunking)
So I need a replacement shower that is half decent that will accept pipework and cable coming in top left and surface mounted.
Cheers people
Well you are going to have to go for another Mira shower if you want to stay with left hand entry as most decent showers done right hand entry to try to take on triton,the cabling will be long enough and fit both types,however as surface pipe work,can not you re run to right hand side,this will give you a lot more options of showers and makes and cost of unit can be reduced
Miras keep on left as think they can do there own thing and think once one fitted due to pipe work,another will be fitted as replacement and thats what keeps them going
IMHO
Thanks, will look out for a Mira then.
The guy wont want me running pipework around the shower to the right as its all surface and doesnt want hassle of re-tiling, so chopping it into the wall isnt an option
Triton tx80 you can get a plate to go on the back which allows the water and electric to come in anywhere within the casing. perefect for hiding old screw holes etc.
Nice !
see there is a triton t80z
that inlet swivels that allows right or left hand feed,price good as well
can replace most electric showers
Below example only,do not know suppliersbest shop about if you require unit
Triton T80Z 8.5kw Electric Shower White / chrome
Nice !
The back plate is called a insta trim Triton Instatrim Back Plate FITS T70/T80/T100XR FOR EASY INSTALLATION - £13.95 - INSTATRIM01 - - BuyaParcel.com - £3.95 Delivery On All Orders! fits most Triton showers to make them fit anything, truely universal shower replacement.
Reply to the thread, titled "Reccomendations for replacement leccy shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
