Recommendations to replace this in landlord property
View the thread, titled "Recommendations to replace this in landlord property" which is posted in UK Plumbers Forums on UK Plumbers Forums.
armyash
Subscribed
Hi everyone
Another post from myself to add to the list if not a problem.
What would you be replacing this with in a landlord property? He's not too bad, doesn't want to penny pinch and put in the cheapest rubbish available but wants reliability and not be ripped off. What would you go for?
I've added the image to the first post for you. 🙂
How do you mean? The Ifos, (In Flue Outdoor Sensor) just clips to the flue terminal and the wire is run through the flu air intake, straight into the boiler.
I was thinking wc sensor also that effects hot water aswell so can have a problem with legionnaires as it won’t get upto temp
Reply to the thread, titled "Recommendations to replace this in landlord property" which is posted in UK Plumbers Forums on Plumbers Forums.
armyash,
ShaunCorbs,
