Releasing recessed holding nut to replace ceramic cartridge on watersmith tap
View the thread, titled "Releasing recessed holding nut to replace ceramic cartridge on watersmith tap" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, I've been trying to find out how to release the retainer nut on a watersmith (Screwfix) mono bloc basin mixer tap. It does not have a hex nut but rather a recessed nut with two flat pieces opposite each other and elliptical the test of it. No space for grips, adjustable spanners etc. I've looked for mono bloc spanners, even have one already which is hex shape and 27mm. It needs to be 28mm I think and I'm not sure if there's a special tool or there for the job. There are similar mono bloc spanners with hex one end and two flat parts the other but I can't find one big enough online. The cartridge is 33mm. Little space between the nut and tap body. This is after pop up shroud had been removed. Nothing else comes off the tap body. Screwfix people who do their Q & A don't seem to know their own taps and can't help. I'll attach a picture of the recessed nut. Am I missing something here? Some simple thing. Or is this a problem for others. Couple of plumber friends don't know and just day they would replace the tap on is entirety. There are two of them so cartridge change will be about a tenner as opposed to two taps at £100+ Can anyone help me? Thanks
Tbh - Screwfix will buy taps in, so probably won’t know their taps, I’d say that shroud will unscrew. Failing that, new tap would be better.
I was gonna say, cartridge for a fiver - unlikely.
In answer to your question - I would get an old screwdriver/chisel and using a hammer drive the retaining ring anticlockwise - a couple of blows will put a dent/slot into the soft brass which you will then be able to locate the blade in and knock it round.
I have done this a few times, but like the lads say - usually replace the tap.
Thanks. Sounds about the only way. I have already bought the cartridge for a fiver btw do if I can get the retainer nut out it'll save me £45 per tap. That's a fair whack to me. Thanks again
Ps to add to first reply, the ceramic cartridge is separate to the retaining nut so I'll be having to get it bask in again after changing the cartridge. Is your method still what you would suggest? I want sure if some cartridges had the retaining nut as one piece, that is with its own hex nut?
Yes, use this method then just knock round clockwise to refit - I would cut a small notch into the ring with a hacksaw once it’s removed, slightly angled to aid knocking around as you will need to get it quite tight. Cut this notch in a different position from the one created in removing the nut.
Reply to the thread, titled "Releasing recessed holding nut to replace ceramic cartridge on watersmith tap" which is posted in UK Plumbers Forums on Plumbers Forums.
andrewna1,
andrewna1,
