View the thread, titled "Removed radiator no - now no hot water or heating" which is posted in Bathroom Advice on UK Plumbers Forums.
R
Robomonkey
Hi all
I drained my system earlier because I broke the radiator feed below the valve trying to undo the tightest nut in the world (still can't undo it with the rad off the wall!), anyway I've fixed the problem reinstalled a new valve and capped them off.
however now I have no hot water or heating, when I turn the boiler electrics back on I can hear the Groundfos pump upstairs start, but I don't hear the boiler fire up, the pump runs and gets very hot.
ill post some pictures in the next reply.
When I drained the system I did the following:
1. Turned the boiler mains off and switched the heating to off
2. Closed the gate valve from the small f&e tank
3. Also closed the gate valve on the heating circuit
4. Finally for luck also closed the hot water cylinder feed gate valve
5. Then I put a hose on the drain radiator downstairs and opened it
6. After awhile I opened the upstairs bleed valves then the downstairs
7. Then I did my repairs and capped the rad valves
8. Then I reopened all the gate valves and listened to the system fill up
9. Finally after a bit of groaning i bled all the rads from the bottom up and turned the boiler electrics back on
my system is a traditional vented system installed in 1994.
Some more info,
ive re-bled all the rads, no air, and plenty of water coming out.
i can't find any bleed valves in the airing cucupboard.
Both f&e tanks are full and working, I.e. topping them selves up
Hi
Thanks do you mean the dead end bit, that looks like an ejector seat button?
isnt that meant to be automatic?
That's awesome, you won't believe how much air came out of that.
I've now turned the boiler electrics back on, and the water is gurgling like crazy with the pump pumping water around, but the boiler hasn't actually fired up.
Should I leave this for awhile? Because I can hear the water gurgling that must mean air is still in the system will that eventually find its way to the aav?
Dont bleed your radiators with the pump going, its most likely SUCKING the air into your heating circuit not BLEEDING the air out.
It sounds the exact same as bleeding radiators
Thanks Koogatubac, the rad bleeding was done with the pump off cos I was scared it would burn itself out with no water. Anyways water was coming out of all the rads as opposed to air going in.
just need to boiler to fire now.
(do boilers run on Windows then)
not sure what you mean but the air will stay in the pipe and build up, when you switch boiler off it releases it and moves it upstairs, eventually it will move enough to get circulation around the system. may still have air in system and some rads may not work but should get system up and running
Lol, sorry bad bad joke, I was referring to the 'turn it off and on again' magic fix that fixes most computer problems.
tried it 3-4 times, so far no luck
Not gurgling anymore, but small amounts of sloshing? I can hear water moving as soon as the pump starts.
as an aside, there's no more air in the aav
depends where you live and what's wrong, but you need an Gas safe registered engineer to come and have a look as not much more advice I can give you
Reply to the thread, titled "Removed radiator no - now no hot water or heating" which is posted in Bathroom Advice on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Bathroom Advice
Start date
Last reply date
Unsolved
Robomonkey,
Robomonkey,
