Removing Air Con units?
View the thread, titled "Removing Air Con units?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
T
TBServices
Been asked to remove some radiators and pipework in a property. They've also asked if can remove an air conditioning unit, to which I replied they probably need an F-gas registered guy, was I correct or did I shoot myself in the foot?
Not worth it tom. You wont know what refrigerant is in it depending on the unit age.
last thing you want is refrigerant burn/frostbite.
Some of the older refrigerants can be really nasty for your health too... I wouldn't fancy a face full of Methyl Formate, Chloromethane or Ammonia.... To be fair they'd have to be old units and predate the now obsolete CFCs and modern refrigerants.
If the units still operate they can be pumped down to contain the refrigerant in the outdoor unit, if not the refrigerant would have to be recovered. But by the letter of the law you need to be F Gas qualified/registered regardless, because you would be deemed as working on a refrigerant system/circuit.
Reply to the thread, titled "Removing Air Con units?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
TBServices,
TBServices,
