Removing cloakroom basin waste - no backnut present ?
View the thread, titled "Removing cloakroom basin waste - no backnut present ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Removing basin waste - no backnut present ?
I want to replace both the tap and the waste in the cloakroom basin - the tap is showing corrosion though it still works fine. Waste is OK but needs to be changed to a click-clack type because new tap will not have the incorporated button/lever which currently pops up the waste stopper.
Problem is that I can't see how to remove the existing waste. I expected there to be a backnut under the basin which could be undone to free off the waste. There doesn't appear to be any nut or any flats that a spanner could grip onto .
I've peered down the plughole from above thinking that maybe there's some screw or nut that undoes from above, but can't see anything.
Any help would be appreciated. ! Thanks.
Reply to the thread, titled "Removing cloakroom basin waste - no backnut present ?" which is posted in UK Plumbers Forums on Plumbers Forums.
Rinnes,
Rinnes,
