Hello this is 10mm pipe how do I remove this from the valve? Does it literally just pull out? Reason being I want to add a JG speedfit coupler to extend the pipe work for a bigger radiator. Is this a system drain down or can you do it live?
Thanks for your reply mate much appreciatedNeed to push the white collar in and the pipe should come out
Drain down
