View the thread, titled "Removing warm air unit ductwork" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
K
Kev the gas
Any different ideas/ tools for removing warm air ductwork?
Over the years I have always used crowbars/ hammers drills for the rivets ect. Is there a magic tool/cutter that is worth having?
Anyone ?
The buggers down here didn't use screws, only rivets and tape that is still as strong if not stronger 30 years later, and then there is the 2 inch ribbed nails they used at the outlets, into the frame work.
Was thinking of a nibbler? Like the sunroof fitters used to use
Use a recip. I like milwaukiee hacksall. Fit it between duct and sleeve cut right through rivits. Or drill / punch them out
I have the recip saws, 240 v and bosch 10.8v.
The hackzall blades seem hard to find on the net, I normally use the makita/ bosch blades. I have the milwaukee demolition blades.
I just use the cheap blue ones at poo fix they are identical to Bosch. Recip comes from toolmonkey it's 18 v tho.
Tool Monkey Ltd
Building Materials Supplier
Clipstone Brook Industrial Estate, Cherrycourt Way, Leighton Buzzard LU7 4GP
01525 374287
£129 bare delivered next day
Reply to the thread, titled "Removing warm air unit ductwork" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
