I am not requesting technical advice on how to do this - merely a basic recommendation from a professional as to whether it's worth repairing my boiler.
(Croppie has accepted this proposal - as I'm not actually asking anyone to tell me how to do this myself).
Currently the boiler is not working - I have had an engineer check it over - so took some photos at the same time.
The fault is possibly due to insufficient airflow through the heat exchanger: when you switch it on, the piezo igniter just keeps clicking but you don't actually get ignition. The fan is working. When you remove the 2 exterior covers, so that the gas jets are exposed, and then switch it on it ignites immediately: the GSR showed this to me when on-site.
I have attached a pic of the heat exchanger - which looks pretty clogged to me - so seems a reasonable assumption that no air is being drawn through it - and hence no combustion.
I'm no expert, but the GSR did quote for repair £1000 and replacement £2700.....this seems expensive to me for a 15kWh boiler that only has to run 2 sinks, one bath and 5 rads.
So, bearing in mind the photos - do you think this heat exchanger really is 'toast'? i.e is it worth me bothering with a repair - or should I just get some more quotes for replacement?
Any help anyone can give would be much appreciated.
