Repairing a dripping tap - what’s next?
View the thread, titled "Repairing a dripping tap - what’s next?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Spinball
Subscribed
Hello folks, I’m trying to fix this slow leaking tap myself and I’m stuck here.
How do I dismantle it further to replace whatever needs replacing to fix the drip?
(The chrome ring round the top will not unscrew by hand.)
Many thanks
First you need to remove the chrome shroud- it either pulls off, or unscrews.
The follow what Shaun said.
Ok, I'm worried about marking it. I'll try putting a flannel round it before using a variable gripping thing.
The internal brass ring unscrews and you need a 35mm cartridge
Cartridge. Like for 80's video games? I'll hopefully get it apart and then take the innards to a plumbers merchants and ask for a new Donky Kong cartridge. 🙂
Thanks.
Well it’s not very clear, but I think that chrome shroud needs to come off - and the fact that it’s threaded on the inside (good spot Shaun) makes me think it will unscrew rather than pull off.
Try wearing rubber gloves for grip, try penetrating fluid, try hot water poured over the shroud, try a rubber strap wrench…
30 minutes trip and £11 at Toolstation and the ring came off. Now what?
(I don’t have an adjustable spanner big enough to grip the flat spots on the threaded bit showing here).
You got it, the next thing is to unscrew the slim brass retaining nut.
Tool in ease of use/least likely to damage anything: a socket on a ratchet handle, a spanner of correct size, an adjustable spanner, a pair of stilsons, a pair of adjustable grips (water pump pliers).
If you don’t have any of the above; buy or borrow.
If you don’t want to, there is a nasty/dirty way of doing it - but potentially damage may occur… you can cut a shallow notch into the top surface of the retaining nut and insert an old flat bladed screwdriver at a slight angle. Then use a hammer to knock the end of the screwdriver so as to unwind the nut. (It is best to get someone else to hold the tap steady for this method - but really it’s a last resort as it can easily damage the nut - or slip and damage the chrome)
Go buy yourself a nice adjustable spanner - it’ll come in handy in future.
Thanks for the tip. I'll get one tomorrow. And I'll squirt a load of WD40 on it before I set off.
I bought an adjustable spanner but the nut absolutely refuses to move. In fact it’s become a bit oval and the spanner just slips round and is flattening the thread.
Any further ideas before I give up and call a plumber?
Ok so an electrician who was installing some lights for us also does taps and he managed to get the cartridge out. It required a better clamp and a certain level of “f it” when applying the right amount of force.
Next up is finding the correct cartridge. Searching for the product code N35HBS does not return anything in the UK.
Can anyone point me in the right direction please?
The only tap cartridge that resembles yours is this one. N35HBS - http://www.geargroup.cn/ProDetail.aspx?id1=4&id2=7&id3=92
It's from China where your tap was made.
Looking at the damage to those threads on the tap, maybe a new monobloc with a hot and cold separate cartridges might be an idea.
That is my thinking as well. Thank you very much for confirming this. And it has made my mind up that I’m going to have both taps replaced.
Thank you everybody for your advice.
Any time we come across one of these taps dripping, we replace the tap, its not worth all the messing about to try and get the cartridge out and then source a replacement. You can usually pick taps up for £50 out of Screwfix and the repair can be made that day
Reply to the thread, titled "Repairing a dripping tap - what’s next?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Spinball,
Nwalky,
