Hi all
A lot of new build houses now seem to be done in Speedfit with the plastic pipes running down the walls to a wall plate behind the radiator, then out into the rad valves.
I went to a job a couple of weeks ago where the guy had gone to hang his clock in the dining room and put a screw through one of his CH pipes.
I cut a section of wall out and repaired the damaged section, however I had to cut a chase into the block work behind the coupling I had attached, as it would have been nearly sticking out of the plasterboard otherwise.
My question is; is there any easier way of doing this, it must be quite a common problem.
Regards
John
Regards
John
