Repiping Central Heating System Advice
View the thread, titled "Repiping Central Heating System Advice" which is posted in Central Heating Forum on UK Plumbers Forums.
I am repiping my whole house and changing from combi boiler to a 30kW system boiler & 250Ltr or 300Ltr unvented indirect hw tank.
Can somebody give advice on my rough plans/sketches for repiping my radiators using 22mm & 15mm. I have only shown the flow line as the return line will just be a replica. I have attached blank drawings if anybody could shown me a better way.
Is my boiler and hw tank size sufficient for this?
Thanks in advance.
1 15mm
2 22mm
3 28mm
Are the last 2 pictures on zone two joined eg up stairs and down stairs or are they individually run / zone 3 etc ?
1 15mm
2 22mm
3 28mm
Thanks for the reply. The last 2 pictures on zone 2 will be common from boiler to inside house then the will be tee’d so 1 pipe upstairs then another pipe downstairs
Can I ask explanation for why 28mm pipe used?
Because of part L regs all homes must to suitable going forward for an ashp and a max flow of 55 used to calculate rads and pipework
Would use 28mm on the upstairs until it splits off then go off the drawing
Thanks for the information mate, ill look into this.
I was hoping to avoid 28mm cooper because of the price haha. If i need to use it then I will just have to bite the bullet.
Reply to the thread, titled "Repiping Central Heating System Advice" which is posted in Central Heating Forum on Plumbers Forums.
ScottInnesx,
ScottInnesx,
