Darville
Hi Guys,
I'm a DIY-er, I've replaced a couple of rads in the house before, and fitted new TVRs on all the rads. So I'd like to think I have some idea about what I'm doing :whatchutalkingabout
I replaced the rad in the lounge on the ground floor over the summer. New one is a column type, so had to cut the feed and return pipes to length. Finished up the job, pressurised the system, bleed the system etc. The rad was full of water. No leaks. All good I thought. Nailed the floorboard back down. I didn't need the heating on then so left it.
Turned the heating on a couple of weeks ago and new rad was not getting hot - others are all fine.
I've balanced the system (or tried to) and still nothing. Re-bleed the system - that all seems fine.
I'm running of a combi-boiler - Worcester Greenstar, which is on the middle floor of a three-storey house.
TVR pin is NOT stuck.
Odd thing is that when I turn the TVR on there's no sound of water running into the rad and it's not bringing the boiler on.
Any ideas gratefully received. Otherwise I may have to give some money to a proper plumber :yes:
