Replacement Cistern flush valves
View the thread, titled "Replacement Cistern flush valves" which is posted in UK Plumbers Forums on UK Plumbers Forums.
My toilet flush valve is continually draining (the rubber seal has perished) . . . I'd be grateful if someone could give me a link to parts that will fit in there and replace the current valves?
Thanks for that link . . it is the rubber seal that has perished and it may be that simply replacing that would do the job . . . . are they a standard part / fit . . . . what is the white part in the pic in the link ?
Which is the link I’ve supplied they’ve updated it to a silicon one due to the rubber failing over time
You have to remove the centre clip you can bust the old on as it comes with a new one etc
How to do it
Reply to the thread, titled "Replacement Cistern flush valves" which is posted in UK Plumbers Forums on Plumbers Forums.
Bagshot,
Bagshot,
