View the thread, titled "REPLACEMENT SHOWER HEAD ARM ADVICE: WILL IT SUPPORT A 300MM SQUARE HEAD" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hello Everyone
I am replacing an all in one shower arm and 200mm square showerhead a head has fallen off and I had to remove arm.
I want to replace with a 300mm head like this.
https://www.NoLinkingToThis/p/cooke...ra-slim-square-shower-head-chrome-300mm/5882t
I have now been reading online that a 300mm head might be to heavy for the shower arm and it may cause problems later on.
Please can anyone advise if if it will be ok to fit a 300mm showerhead and arm or should I just get the smaller 200mm head as its lighter.
Any recommendations for a specific shower head and arm would be much appreciated. Is it worth paying a bit more?
I have attached some pics of broken head and arm
Thanks for your help in advance
Peter
Probably more to the point have you sufficiently flow/volume from your shower mixer to make the bigger head usable?
May be easy to change the arm probably 1/2in male thread but will depend on how well fixed (or not) the connector behind the tiles is.
Hello
Thank you for your quick response. I have taken the arm off carefully and you can see the pictures below where it was connected to the wall. The house is supplied by a megflow and combi boiler system in the loft
Will this be enough pressure to supply the 300mm head ? Will the 3000mm head be safe on arm?
Thanks Again for your help
That head gives a max of 12ltrs a min output. Maybe temporarily put old arm in run shower into a bucket for 30 seconds if you have 6lts or more your in business.
As for the arm standing weigh that really depends on how well fixed the connector in the wall is.
Hello Everyone
Sorry to bother you again
I bought the Bristan arm and head as the local plumbers merchant recommended it as well. The
shop said I could just screw it in sane as the old one. However it has come with a back nut and lock nut as well which the old arm did not have.
I just wanted to check are these nuts necessary?
The instructors also state that compound is required. Once again is that necessary and where should I add it.
Finally I have noticed the thread going into the wall on the new shower arm is longer that the old arm. Will I need to cut this down?i have added a picture of the new and old arm.
I have attached some pictures.
Thanks again in advance
Your old arm has a bezel/cover plate to hide the hole in the wall.
Does your new arm have similar? If so I guess the back-nut with two flats is to hold that on.
I don't think you need the other one in your situation.
Looks like you'll need to shorten the thread, but the old one looks too short. Better to do some careful measuring and try to leave the maximum thread that will let you get the cover plate flush to the wall.
The backnut is for use if you have access to the reverse side, or open studwork or some such - you can’t use it in your situation.
You will need either ptfe tape. or loctite 55 cord or loctite 577 sealing compound on the threads of your shower arm - which will also need shortening.
Hello Ben
Thank you for your advice. I got it fitted and working yesterday. I will need to take it off and cut it down as you all have suggested. Biut I had to get it working yesterday or their would have been a family revolt... Should I cut it with a hack saw or pipe cutter?
Thanks to everyone who has responded
Peter
Hacksaw.
Try to cut it square.
And de-burr it, and clean off any swarf or filings before fitting it.
I normally try to dress the new start of the thread, where it tends to have a sharp edge.
Dunno what others do!
Good luck 😀
Shaun got there first!
Reply to the thread, titled "REPLACEMENT SHOWER HEAD ARM ADVICE: WILL IT SUPPORT A 300MM SQUARE HEAD" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread starter
Joined
General Plumber
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Peter T,
Peter T,
