Replacing a mixer
View the thread, titled "Replacing a mixer" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Until the entire bathroom is replaced, looking to swap out the mixer as it doesn't mix very well. The pressure also used to be much better and its now merely a dribble so hoping that replacing the mixer for now will be a fix. Assuming its just knackered out inside and full of scale.
Is it a case of turning off the water, undoing, replacing and turning on the water again to achieve a like for like replacement?
is there anything else that I should be aware of or consider? obviously i'll fix a compatible mixer in the correct size.
replacing something very similar to this:
check the flow without the head on the hose, it could be scaled up which is a cheaper fix just to change the head
All sorted.
Flow is much better than before, but still won't be good enough for a rain shower. When the bathroom is done i'll get a new tank/pump put in as suggested on here in a previous post.
I replaced mixer and seals, hose and head with a budget set for now as plan to redo bathroom in a month or two.
All sorted.
Reply to the thread, titled "Replacing a mixer" which is posted in UK Plumbers Forums on Plumbers Forums.
kash,
kash,
