Y
YoungPlumb
Hi guys, just replacing a dual flush push button siphon, as the seal on the previous one was knackered and it was only a single flush siphon, so i thought its cheap enough, replace the hole thing!
Ive fitted it with the following fluidmaster:
Fitted it fine no problem, but now its not seeming to flush propperly unless you keep you finger pushed down on the button, ive tried adjusting how much water is flushed, Max & Low. it does it on full flush and half flush! It attempts to flush and then just stops and the cistern fills back up.
Also it makes a clunking noise when it seals after a flush.
Any help would be much appreciated, i have a video of what happens which i can send you but it won't let me post links on here!
