Replacing a radiator and Valves
View the thread, titled "Replacing a radiator and Valves" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi All,
I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also need to remove both valves and make the pipes shorter.
Its a gravity fed system and the last radiator in the system , I have a bung kit, i know i can cut the feed pipe into the radiator st there will be a vacuum, but does this also apply to the pipe/valve on the return/drain side ?
Reply to the thread, titled "Replacing a radiator and Valves" which is posted in UK Plumbers Forums on Plumbers Forums.
PatBoySlim,
PatBoySlim,
