Replacing bathroom radiator valves
View the thread, titled "Replacing bathroom radiator valves" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Trying to change bathroom radiator valves but I can’t get the old olive/nut off… any advice?
Also the small plastic part next to the pipe, will I need to put that back in before fitting new valve? (Complete novice)
Your fecked now should of used the old nut and olive now you need to cut the pipe back and use a coupling if you haven’t any slack
You have to cut it right below the bottom of the olive
Reply to the thread, titled "Replacing bathroom radiator valves" which is posted in UK Plumbers Forums on Plumbers Forums.
Abbiel123,
Knappers,
