T
thebigred
I have a failed expansion tank (which is full of water and has 0 bar pressure) on my unvented hot water storage system. Currently the pressure relief valve is venting water to the overflow.
This diagram matches what I have:
I want to try and do the job myself if possible but it seems these types of systems are not very common and most plumbers merchants I talk to seem to think I'm talking about a sealed combi system (i'm not, it is a text book unvented hot water system, i've checked the standards doc)
My plan is to do the following:
0. Isolate the mains supply 🙂
1. Drain the system off
2. Remove the expansion vessel and fit a replacement one
3. Remove the pressure relief valve and fit a replacement one
4. Fit a pressure gauge on the pressure reducing valve (There currently isn't one so I've no idea what the pressure is)
4. Make sure everything is tight (although not too tight)
5. Turn the water back on
I guess my questions are:
1) Does the plan above look good and safe
2) I know the vessels come pre charged with about 2 bar, but how do I calculate how much pressure I need in my system?
3) I presume I need to put pressure into the vessel before I put water back into the system
4) The vessel currently in there is a 18L 10 Bar Max one? - Do I need to replace it with another 10 bar max one? Most I can find at merchants and online are only 3/4 bar max? (It's a white Zilmet one model 0036)
5) I've been quote £200-300 by the company that installed the system to do the above job - to me that seems pretty high but I'd welcome any advice - perhaps it's a bargain and I'm being a tight git!
Thanks in advance
Oli
Thanks in advance
Oli
