AI Plumber
I have read through all posts about lead mains replacement to MDPE.
To get my head round it can any plumbers give a guide to how it's done. I've seen parts of it done once as an apprentice.
In my case there is the drive way. So you'd dig up the drive way from the boundary stop valve to the entrance of the property. My mains stop valve I believe is somewhere close to the main door, underneath the floor boards, or underneath the staircase floor boards.
On the property side, its connected lead to copper so I connect it from copper to 25mm MDPE ? And then on the boundary stop valve side, is it the water board who come and connect that ?
The pipe must be 750-1350mm deep. And from the diagram below it shows that there needs to be a service duct before entering the property. What type of service duct can I use ? Is there any flexy type service duct and how do I seal both ends ?
Also would it increase the flow of mains supply ?
Thank you for reading and would much appreciate your replies.
