View the thread, titled "Replacing programmer" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
mcniven
Weird that this is somethin I have never been asked or done. Iv changed many 3 port valves 2 port valves etc and copied wiring! But a customer today after a boiler swap asked me to swap his programmer because this one is old!
.... Is this a simple enough task? What should I be looking out for, obviously behind this control
Box is a junction box anythin to look out for?
Existing system is open vented pumped s plan
ImageUploadedByTapatalk1374258485.840962.jpgImageUploadedByTapatalk1374258493.231151.jpg
you can just get a jnew updated version which will go on the same back plate. So no need to change any wiring
If you look at some of the manufactures ( of programmers) they can usually tell you what's compatible with that programmer and back plate
when you get a new programmer it should come with a sheet listing different old units and wiring configurations between then and the new one
Reply to the thread, titled "Replacing programmer" which is posted in UK Plumbers Forums on Plumbers Forums.
