Replacing simple flick switch with timer on boiler
View the thread, titled "Replacing simple flick switch with timer on boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I
itnorfolk
Hey Guys,
I have a standard hot water boiler installed, and there is a standard switch to turn it on and off....
I want to replace this with a little 24h timer, enabling me to set it to come on and turn off....
I bought an LG-DIHT timer switch
On the rear the is quite simply AC, COM, then something that looks like WO or NO etc...
Inside my standard switch is:
the live, neutral and earth from the mains, and the boiler as a normal connection...
My question - What goes where? I'm assuming that AC is live in, COM is the grounds and the other connection is the boiler live and the earths are just joined in a block?
Any ideas?
NO stands for Normally Open and NC stands for Normally Closed.
Assuming you don't have the instructions for the timer, I would expect the NO to have zero volts on its, going to 230V when the timer is "On".
I'd wire as follows:
Mains in: Live to AC, Neutral to COM, Earth to Earth.
Boiler Out: Live to NO, Neutral to COM and Earth to Earth.
Youd be wiring it wrong then.
I recommend getting someone competent in to do it imo
Reply to the thread, titled "Replacing simple flick switch with timer on boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
itnorfolk,
Dotty,
